8 members (Hotrod Lincoln, tclederman, ChevyBlue, moparguy, mk72, farmallb, Opelika Tom, Otto Skorzeny),
182
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,055,988 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Hi guys - I got the 58 apache home Thursday at about 10pm. This evening I started the process to replace the rear main seal because the previous owner said it leaked like crazy (it doesn't run at the moment but is all together).
So I pulled the pan & bearing cap easy enough. Cleaned everything etc. Of course the hard part is getting the upper seal out.
HOW THE HECK DOES THIS THING COME OUT??? (sorry for shouting). I tried to drive it out like I would a rubber one, but this rope seal is crap.
The tech tips said to loosen all the bearing caps & drop the crank, but with the transmission/clutch/fly wheel attached & tight how will the crank drop?
Need help! | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | I knew there had to be a tool that would pull this. Can this be bought locally or do I need to order one online? | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Doesn't matter - I just bought one on ebay. Will be here this week. Thanks for the help. I'll let you know how frustrated I am once it arrives. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | That threaded tool is very handy for this. thread it in as far as possible and pull it out. | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you push in and release the clutch with the bearing cap loose the crank should drop a bit. You will want to have an assistant do it again with you when you tighten up the bearing cap again, though.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Thanks for the advice. If I can't get the 'pete' to remove the seal I'll recruit my 7 year old son to help work the clutch while I pry on the crank.
I read somewhere online that if you drop the crank you will guarantee a leak in the front seal. This true? I don't want to cause myself any more problems.
By the way - The odometer reads 56k - could be 156, 256, 356. I don't know - but the underside is very clean - no gunk built up no rust. Been sitting for 15 years. I'm hoping it is just plain ol' 56k.
Oh - since I'm thinking about this - there are a ton of casting numbers & other things stamped on the parts. I have no idea if these are good to know or not, but thought I'd write them down just in case. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Once the rear main seal is replaced, I'm going to rebuild the carb & then drain & clean the tank & fuel lines.
It should start right up after that. | | | | | Joined: Mar 2009 Posts: 208 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 208 | Got the sneaky pete in the mail today - took about 1 hour to complete the seal swap from that point.
Thanks for the help guys. I'll let you know when I get it running. | | | | | Joined: Apr 2005 Posts: 82 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 82 | Midget,
Did you have any trouble with the crank or were you able to pull it through without loosening all of the journals?
As you might guess, I get to do this fairly soon...
Thanks, Richard
Richard 58 3104
