3 members (Gib70, cmayna, baldeagle), 117 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
j54
Offline
I was wondering if the hood latch panel from 53 and earlier were the same as one for a 54? I've noticed some of the parts companies list this part as being for 47-53 and some say 47-54/55. Also what about the center trim strip on the hood?.. is 54/55the same as 47-53? thanks.
i looked at LMC catalog and they don't have a listing for latch panel for the gmc but other parts are listed together as the same ie. hood bolt. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
j54,
Are your referring to a Chevrolet truck or a GMC?
Tim
j54,
If you are referring to a Chevy, I am very interested in the answer to this question too. Parts for 48-53 are much easier to come by. They can make a very nice substitute on my 55 first if they fit.
The 1929-1957 Chevrolet Master parts catalog seems to indicate the upper radiator grill baffle part number is 3700834 for 47-55 first. I may not be reading it correctly though because I have pics of two different baffles in my photos (look in the 54 grill album). The baffle I believe to be 47-53 fits O.K. but as you can tell from the pics there are some differences where the grill bolts on.
So in short I think they are different.
Look forward to hearing from tclederman as well. He has a ton of info on the 54s.
Eileen,
I am not much help on that hood latch panel. I have read peoples' posts here that the hood latch panels are the same for 47-55 and I have also read that they are different 47-53 vs 54/55. And, I have read what you posted above about the one part number in the MPC for 47-55.
jj54,
The hood strip is the same from 47-55 (but it different for Chevrolet vs GMC hoods).
Tim
The hood latch panel will fit '47- '55 1st Chevy truck. The difference is on the '54-'551st ,there are 2 exposed rivet heads that hold on clips on the underside of the panel. The wiring for the passenger side head lights and parking lights were run behind this panel starting in '54, instead of passing over the top of the panel at the radiator core support top cross piece.
j54
Offline
Yes I was referring to a Chevy, sorry forgot to mention that. Thanks guys.
