| | | Forums66 Topics128,081 Posts1,056,319 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Hey Yall....... Yes, alive and doing quite well. I'd like to change from non detergent to detergent in my 235. What is the best method. Haven't dropped the pan for 3-4 years but last time I did it was cleaned out completely.
Should I drop and clean the pan, change the filter and simply load up the engine with some 30w detergent?
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Craig,
It is no big deal to stick new detergent oil in your rig. The only concerns would be that this new oil would loosen up any old gunk and tend to plug small orifices and/or a oil filter. I personally don't think the detergent additives in the modern oil are that aggressive.
The oil has components in it that encapsulate any contaminant and hold it in suspension so it can be flushed when you drain your oil. That is why oil turns black...it's all the junk the oil is holding within itself, junk that isn't deposited on the interior of the engine.
All this BS aside, I would put your new oil in along with a new filter and run it for a thousand miles or so. Then drain it and replace the oil and filter and follow the regular drain schedule.
Stuart | | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Eureka? I think I remember you back when I was more of a regular on Stovebolt. During May I'll be driving the goat through Eureka from Bend, or. Went to CR and Humboldt during late 60's/70's
So since I've cleaned out the pan a couple times before, just skip dropping it?
I sure wouldn't go to the bother to drop the pan especially since you've done it recently. Swapping from non-detergent to detergent isn't a real traumatic event.
Drop me a note when you're in the area and we can swap BS.
Stuart | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If you cleaned the pan recently, I agree with Stuart.
However, if the engine has not had the pan cleaned recently, I think I would go through the effort of cleaning the pan before switching to detergent oil. This is just precautionary and might be unnecessary (as Stuart suggests).
| | | | | Joined: Jan 2002 Posts: 2,841 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,841 | Well it's been probably 3 years or 1500 miles since I dropped it. What is the most popular 30w detergent oil to use?
| | | | | Joined: Jan 2007 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 83 | I agree with these guys, if you only have 1500 miles since cleaning the pan just change to the detergent oil. I am using the Rottella T | | |
