3 members (Gdads51, 2 invisible), 333 guests, and 6 robots.
Topics128,162
Posts1,057,068
Members48,463
#52156 11/09/2005 9:33 PM
Befor I replace the bed it's easyer to stop the leak on the rearend and also the driveshaft to rear seals. It's a ten bolt rear and I don't know where to get the gaskets for this 3/4 ton 3600. Also how do I go about re gasketing it?
PJP
Riding in the Passing Lane
If it,s leaking at the pinion seal where the drive shaft yoke goes into the rear end you pull the drive shaft loose. Than remove the yoke. Than remove the 5 bolts that hold the flange with the seal. Replace the seal & reassemble the parts. The gasket & seal can be purchased at a parts store or American Classic parts. If the rear cover is leaking you can remove it & replace the gasket. If grease is leaking out the rear drums you will have to pull them & replace the seals.
1972 Chevy c10 Cheyenne Super
I made gasgets out of a thin cardboard... used the old ones as a template....and they're working real fine!
Larry Bear
55.5 Chevy 3100 Panel
PJP
