| | | Forums66 Topics128,089 Posts1,056,005 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Can anyone help me figure out if the foot pedal starter and linkage from a '59 Apache (second series cab) will be the same with respect to the cab location and starter pedal of a 1952 1/2 ton (first series) matching up to the 235 engine? Basically the pictures I have seen look the same but I never had the original in the 52 so I don't know if they will match up.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I guess you don't have the 52 bell or linkage? I'm running a later 261 in my 46, using the OLD 216 original bell and starter set up, so you can stay with the old stuff even is using a later motor. If that's your question??? | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Thanks for the reply Shark. I don't have the original 52 bell or linkage. It sounds like the starter linkage gets attached at the bell housing flywheel area which would change depending on the motor year. If I don’t have the OLD 1st series bell housing then the hole in my cab which is offset from the gas peddle might not match up.
Your not trying hard enough if you don�t screw up every once in a while.
52 1/2Ton 235 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Kev - I don't think that setup on the bellhouseing changed at all during the period the foot start was used, and the bellhouse mounting should be in the same position with regard to the cab, I'd expect the later one to fit fine, GM was good back then on not redesigning something that didn't need it
Bill | | | | | Joined: Aug 2008 Posts: 28 New Guy | | New Guy Joined: Aug 2008 Posts: 28 | Thanks Bill - Appreciate the assist. Important to keep the original stock elements and this helps. My 7 year old niece thought it was “neat” that she had to roll the windows up and down by hand.
52 1/2Ton 235 | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can't put a '59 bellhousing in a '52 without modifying the frame. The way the bellhousing mounts to the frame is completely different. It changed in '54.
