5 members (Charles in CA, klhansen, FishinToms53, Hanks custodian, 5 Window 9434), 53 guests, and 0 robots.
Topics128,049
Posts1,055,634
#521301 03/26/2009 10:55 PM
How do you replace sun visor pads with out damaging the new pads. I see the rod is bent so the pads will stay still. Do I need to straighten the rods before tempting to but on new pads.
1951 Chevy 3100 Deluxe 5-window
Four generations and still not for sale!
More pictures in Photobucket
David
David Sr #521320 03/26/2009 11:49 PM
David,
I can't recall ever seeing a bent sun visor arm. I wonder is this might have been an owner adjustment for a freely flopping visor?
Tim
That could be the ticket Tim; both of mine were bent in a wavy way that it just looked factory. The old ones pulled off hard and after destroying a new pad just wanted to make sure before straighten the rod.
David
David Sr #522164 03/29/2009 11:24 AM
I should of none this by now. The USA and the Over Seas measurements are not the same. After straighten the rod on the American bracket it still would not go in to the new pad. Try putting back into the original pad and went in to easy. I had to end up shaving down the rod to make the two countries come to gather again.
David
Moderated by  ndkid275, Phak1
