0 members (),
79
Mod | | | Forums66 Topics128,021 Posts1,055,373 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | How do you replace sun visor pads with out damaging the new pads. I see the rod is bent so the pads will stay still. Do I need to straighten the rods before tempting to but on new pads. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | David, I can't recall ever seeing a bent sun visor arm. I wonder is this might have been an owner adjustment for a freely flopping visor? Tim | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | That could be the ticket Tim; both of mine were bent in a wavy way that it just looked factory. The old ones pulled off hard and after destroying a new pad just wanted to make sure before straighten the rod. | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | I should of none this by now. The USA and the Over Seas measurements are not the same. After straighten the rod on the American bracket it still would not go in to the new pad. Try putting back into the original pad and went in to easy. I had to end up shaving down the rod to make the two countries come to gather again. | | |
