3 members (Gray_Ghost, tesa, Johnny N), 88 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
#52111 11/09/2005 3:18 AM
Hi Bolters!
I am finally getting my rebuilt 216 back togather, and I am needing to know how to properly, give the rocker arms an initial adjustment, prior to starting the engine. Everything in the engine is new. I also replaced all the pushrods, lifters, and one rocker arm, that was broken because of a stuck valve before the engine was overhauled.
Thanks in advance for the info!
KT
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#52112 11/09/2005 6:16 AM
First, have you ground the face of the rockers smooth? This is where the rocker hits the valve stem. If there is a ridge from wear, you won't get the valves adjusted right.
To adjust the valves on a new engine, simply follow the procedure for a warm engine. Last I looked there was a tech tip or two on it. It won't hurt to use the gap for a warm engine, as long as you're not running a huge cam.
After your 20 minute cam break-in, then reset the valves while the engine is still warm.
Another tip on a fresh engine is to use straight water for coolant. Seems like when I use antifreeze I end up with a leak, and straight water is a lot easier to deal with. Of course, add antifreeze once you know there aren't any leaks.
Fred
52 3600
69 C-10
#52113 11/09/2005 1:19 PM
I
I Offline
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#52114 11/09/2005 3:20 PM
kt
When I first attemped to do a valve adjustment on my 49 216, I had the tech tip printed and on the fender with me. I struggled to do it accurately and ended up with a truck that ran very poorly. After consultation here I did COLD adjustment to .010 and .020 where I could take my time and get the feel and position done correctly. This initial adjustment worked great and allowed the truck to run fine. I did get a hot adjustment done later, but very little changed from the cold adjustment.
dave s
#52115 11/10/2005 4:38 AM
Thanks to all who replied. Hi Dave! I have a 235 that the mechanic who overhauled it, adjusted the valves before the engine every ran, and when I put it in the truck, it ran great! I have been told that a good mechanic will adjust them slightly loose. I have never done this before, and I appeciate the tips!
KT
