0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52102 11/08/2005 5:10 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | Hello people Iam looking where to find an overdrive unit for a 1963 gmc four speed,I have heard about them but never seen one,any tips or links would be much appreciated!  | | |
#52103 11/08/2005 6:07 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I was going to post some ideas, but looked at your profile and found this is for a Napco 3/4 ton, and the suggestions won't work for a 4WD.
You can regear both differentials or replace the tranny with an overdrive unit, the most popular is the 700R4 automatic.
Fred 52 3600 69 C-10
#52104 11/08/2005 6:20 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | thank's for the reply,why won't it work on the 4x4,is it because of the tranfer case?.Iam probably just going to run taller rubber if the overdrive can't be done,that should get another ten mph! which is all she really needs  | | |
#52105 11/08/2005 7:58 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | There isn't enough space between the 4-speed and the transfer case to put in an overdrive, even though they are a divorced setup.
You MIGHT be able to fit a Ranger overdrive (Advanced Adapters) between the motor and transmission but it would significantly shorten the divorced driveshaft unless you moved the divorced transfer case. This would cause you to modify the length of both driveshafts. You MAY be able to convert your 4 speed and transer case (probably need to swap to a later NP-205 if you have the Rockwell T-221) to a married style, this would give you room for the Ranger and wouldn't cause too much change to the driveshafts.
You could possibly put a overdrive after the transfer case, but you could only use it in 2wd, and you would have to modify the length of the rear driveshaft. I don't know if those planetary gear overdrive will mate to the output of a transfercase or not. | | |
#52106 11/08/2005 8:40 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | thats fine! if it can only be used in 2wd,cause that would be the only time it would be used(on the hwy!).there isn't any room between the engine and trans,but aft of the trans case seems like the place ,any info on were to find these units would be great!thanks for the input!!  | | |
#52107 11/09/2005 1:21 AM | Joined: Mar 2004 Posts: 154 Member | | Member Joined: Mar 2004 Posts: 154 | if you have a 3 speed OD, the tailshaft can be used in place of the 4 speed. i'm not sure of the saginaw or muncie specifications. but i beelive someone has done it on here. or maybe its on inlinrs. i'm not sure. check out the archives, with a search top be sure. 1969 K20 , with a '67 front clip. fleetside. 292, 3x1 offy, headers. sm465 4spd. getting put back together, almost ready for paint. doing it all myself. 19 and lovin' it. "proper" is so over-rated. .later days. .sam.
#52108 11/09/2005 5:38 AM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | | | |
#52110 11/09/2005 3:51 PM | Joined: Jun 2005 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 128 | thank's for all the great info guy's,now I've got somewhere to start,and that's down in the shop to make some cash to aford one of these babies!!!  | | |
