6 members (Otto Skorzeny, Lightholder's Dad, Hotrod Lincoln, Rusty Heaps, rfs56trk, GRNHydra), 130 guests, and 4 robots.
Topics128,164
Posts1,056,968
Members48,458
Apprentice
Apprentice
I am the new proud owner of a '51 3600 and am having difficulties with my master cylinder rebuild, I put it all together and test the new pump (not hooked up with only fluid in the resivour and cannot get it to pump. Any ideas? I have gone over the shop manual and am still having trouble with it, and I just don't want to break down and buy a $100 new cylinder if I dont have too. None of the passages are blocked so I'm hoping it's just my crappy rebuilding skills. Thanks for the inputs!
Riding in the Passing Lane
If the line is not hooked up put your finger over the outlet hole when on the return stroke. You probably have air in it. If that doesn't work you will have to take it apart again. The cup in the center faces back. It's pretty basic. It would be hard to get it wrong.
1972 Chevy c10 Cheyenne Super
Y
Y Offline
One other thing, are you pulling the push rod all the way back to the stop? Check for plugged fluid hole, in the bottom of the reservoir?
