7 members (Wickedbass, MRMEROTH11, GradyB, SWEET, TexasJim50, klhansen, TUTS 59), 67 guests, and 2 robots.
Topics128,066
Posts1,055,873
Members48,428
#520599 03/25/2009 1:56 AM
OK I just spent too much money putting clutch and brakes in my 1957 350 gmc, first time out the engine takes a dump. I,m tempted to cut it up for scrap(but temper tantrums don't help) . Is there a later model engine swap that doesn't invole major rework? Oh ,it has pontiac v8 now.
guy51usa #520614 03/25/2009 2:28 AM
what is the pontiac engine that is in it now and is it origional? i have seen older gms from that era with poncho engines before,in gms version of the cameo timbuk
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
Photobucket pictures
timbuk #520622 03/25/2009 2:39 AM
The truck is totally factory stock, 347? pontiac engine.
guy51usa #520627 03/25/2009 2:45 AM
that sounds about right you will problably have to change your bell housing to go to a chevy engine you may be able to reuse your clutch but you would need a different flywheel it all depends on the bellhousing bolt pattern not to familar with the old poncho engines-do not know if the ones from the 60s are the same bolt pattern-you will need to research....timbuk
65 Chev shorty
65 Chev longbox
65 Chev crewcab
65 Chev bus!
timbuk #520777 03/25/2009 3:37 PM
That motor became the 389, 400, 455, so I would expect any of those could easily be adapted to fit.
There are some differences between the motors externally, and I'm not an expert so I can't tell you want they are. At one time I toyed with dressing a Pontiac 455 as a 347 for a truck project, and my conclusion was it could be done as long as no one who really knew Pontiac motors was looking at it.
