0 members (), 67 guests, and 3 robots.
Topics128,055
Posts1,055,782
I have a 55 2nd series Chevy. When I bought the truck the speedo cable was broken. When I was redoing the interior I removed the gauge cluster, blew the dust out of it and tested the speedo with a drill. It worked fine up to 30 mph (that is all the faster the drill would turn it). A few months later I bought a new cable and lubed it lightly with a white grease stick. After installing the cluster I took it for a test drive and the speedo needle was jumping wildly below about 30 mph and over 30 mph it would peg over to the 100 mph side and squeal a constant squeal.
I removed the cable and oiled it with a light Teflon oil and re routed the cable to make sure there were no sharp bends in the cable but the problem remains.
So the question is that I have is this...Is it a problem with the cable lube or the speedo head its self? BTW the odometer dosn't appear to be working correctly either.
Thanks.
the speedo head is gummed up, see if this tip helps any ... likely you won't get the odometer working as the wee plastic tabs on the number wheels break easy when things get messy in there, might have to find another unit, or live without if you can get the speedo working smooth
