I am familiar decoding the NORMAL factory engine assembly serial number found on machined pad at the base of the distributor. However, when it deviates from the normal factory coding, I haven't found a source to decode it.
Here's my example. I have a 1959 235 6cylinder engine.
The engine serial number is "12745 er CAL".
I believe this is a "replacement" engine. Not sure if GM replacement or from some engine rebuilder shop.
Does anyone know where there is documentation on this type of coding? I would like to learn more.
Brian
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
