0 members (), 361 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
Just wondering what you would use for a excelarator set up for a 350 4 barrel in a 48 1/2 ton. I know there are a lot of options. But, what is the best??
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
I used one front a 1972 Chevy Nova. Made a new pivot and works awesome. Just make sure to have a driver tell you where to weld it first.
I just ordered from Ebay a 73-87 Chevy Truck, Accelerator Pedal Assembly w/Cable IT cost 18.00 plus freight. The seller was:
truckbuilder1968( 1039
Of course it hasn't come in yet so I can't say if it is the right fit.
~Jim
Tom,
mine was a 1970's caddy pedal ..just replaced it with a Lokar cable an there spoon type crome pedal ..so far I like it.
Tim
1952 Chevy Shortbed
Photos in Photobucket
same as tim,lokar chrome spoon and stainless cable,havent installed it yet though..............dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
A stock 1975 pedal and bracket. I got it free when I scrapped the truck. There are 2 different cable lengths, one for V-8 and one for L6. Shouldn't be over $5-10 at the U-pull-it yard. I have been told that the same unit was used from the '60s till 1987.
best wishes,
Les
It seems that a 67 to 87 pedal assembly will work. My question is........ Did any of you have to do any modifications to anything? Will the cable system work on any carb?
Let me know what you think....
Tom
"The Big Dog"
I used a pedal and cable assembly from a late model (1999 or 2000) Chevy S-10. It bolted on perfectly and the cable is the right length to connect with a Holley 4-barrel on a 350 small block. No modifications were necessary.
Here's the accelerator pedal I used.
The cable is a Spectre universal cut-to-fit from Autozone.
More pix on Flickr.
Tom,
On mine with the salvage pedal all my Uncle had to do was make a round hole square for the stock cable to clip into on the the firewall other than that everything was pretty much "Plug & Play", the Caddilac cable was a bit long a cable from a mid 70's malibu was the perfect length.
I had to make the square hole round again for the new lokar Cable to install the new pedal.
Tim
1952 Chevy Shortbed
