10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50), 49 guests, and 1 robot.
Topics128,074
Posts1,055,914
Members48,429
Anyone in here know how to test the sender? My gauge was working fine up until about 3 weeks ago and went back down to empty. When I touch the sender wire to ground the gauge goes to empty. Also, my temp sender never moves past the cold spot. Are they somehow in the same circuit?
HELP!!!!!
Thanks, Steve in Idaho
Yes, a lot of people here know how. They regularly post it in "Electrical Bay". I'm moving this over there.
Ex Hall Monitor
Ex Hall Monitor
HELP!!!!!
Your fuel sending unit should show 30 ohms resistance with the float in the full position and 0 ohms with it in the empty position using a multimeter. Connect the red lead to the wire lug and ground the black lead to the sending unit housing. Moving the float through the full range slowly should show a smooth reading change on the meter.
Thanks Tiny....figured out that float is bad after pulling the three hairs out I had left. I was trying to search the info and guess i was looking in the wrong spot.
Thanks, Steve
