| | | Forums66 Topics128,078 Posts1,056,052 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Anyone in here know how to test the sender? My gauge was working fine up until about 3 weeks ago and went back down to empty. When I touch the sender wire to ground the gauge goes to empty. Also, my temp sender never moves past the cold spot. Are they somehow in the same circuit? HELP!!!!!
Thanks, Steve in Idaho
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, a lot of people here know how. They regularly post it in "Electrical Bay". I'm moving this over there. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Anyone in here know how to test the sender? My gauge was working fine up until about 3 weeks ago and went back down to empty. When I touch the sender wire to ground the gauge goes to empty. Also, my temp sender never moves past the cold spot. Are they somehow in the same circuit? HELP!!!!!
Thanks, Steve in Idaho Your fuel sending unit should show 30 ohms resistance with the float in the full position and 0 ohms with it in the empty position using a multimeter. Connect the red lead to the wire lug and ground the black lead to the sending unit housing. Moving the float through the full range slowly should show a smooth reading change on the meter.
| | | | | Joined: Jan 2009 Posts: 158 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 158 | Thanks Tiny....figured out that float is bad after pulling the three hairs out I had left. I was trying to search the info and guess i was looking in the wrong spot.
Thanks, Steve | | |
