0 members (), 135 guests, and 2 robots.
Topics128,080
Posts1,055,954
Members48,430
#519106 03/20/2009 1:45 PM
I was out messing with my kids '69 Chevrolet 1/2 ton 4x4, 4 speed the other day. I grabbed the drive shaft and turned it. I could turn it a lot! I could turn the shaft from stop to stop 3-4 inches. It appears to be loose in the rear end. Not nowing much about diffs, is this just a matter of re-shimming the gears or is something really wrong? Or possibly is the problem somewhere else?
Bruce
My Trucks
Stuff I Collect
My opinion...sounds like differential...if it is that loose you'll find it has really worn the gears...how about up/down movement at pinion? If that bearing is gone the pinion will 'float' altering pinion depth into ring gear (again causing A LOT of wear....I think regardless I'd be pulling it apart for exploratory surgery........Good Luck!
The rear sounds like it is loose, but if you have no experience with rears, I would not recommend you take it apart. Take it to someone who has experience setting up ring sets.
No movement at the pinion bearing. My knowledge is limited to I know it has a ring and pinion, bearings, bearing caps and a couple other things. I think I'll let somebody else look at it!
Bruce
My Trucks
Stuff I Collect
Mosts used rearends have quite a bit of play in the them. What I mean here is that you can turn the driveshaft back and forth without moving the wheels. There should be no sideways play at all.
1951 1 Ton Completed
