5 members (Otto Skorzeny, Biermann, Ridgeback, Oswald, GMCJammer51), 72 guests, and 1 robot.
Topics128,154
Posts1,056,837
Members48,456
JC
Offline
Hi,
Anyone know the best way to remove the factory vacuum-style governor off a 66 C60 with a 327 and a 2bl rochester carb? I have the motor it in my 66 c20 now.
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
3B Offline
Hy JC, if I'm remebering correctly all you have to do is install a standard carb, and distributer, an H.E.I. distributer may even fit, and would be an excellent upgrade, hope that helps.
JC
Offline
Thanks for the input. That is good alternative that I am considering, but I was wondering what it would take to use the existing parts
JC in KC
3B Offline
Hy JC, if you disconnect the vacuum line to the distributer the system should function as a non governed one, I think, don't forget to plug the source of vacuum you removed, hope that helps.
