| | | Forums66 Topics128,140 Posts1,056,774 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Hi,
Anyone know the best way to remove the factory vacuum-style governor off a 66 C60 with a 327 and a 2bl rochester carb? I have the motor it in my 66 c20 now.
JC in KC "The future will be better tomorrow." Dan Quayle 1965 Chevy C10 Long Fleetside
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JC, if I'm remebering correctly all you have to do is install a standard carb, and distributer, an H.E.I. distributer may even fit, and would be an excellent upgrade, hope that helps. | | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Thanks for the input. That is good alternative that I am considering, but I was wondering what it would take to use the existing parts
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy JC, if you disconnect the vacuum line to the distributer the system should function as a non governed one, I think, don't forget to plug the source of vacuum you removed, hope that helps. | | |
