1 members (baldeagle), 89 guests, and 4 robots.
Topics128,037
Posts1,055,466
Members48,424
#518876 03/19/2009 8:26 PM
Apprentice
Apprentice
I have a 1959 235 engine replacing my stock 216 and I am usuing a adapter plate to raise the water pump to the center of the radiator and will be using a 1954 NAPA water pump.My Question is the water pump pulley seems to small ,the original 235 pump had a bigger diameter pulley ,has any one had problems with the pump spinning to fast or cavitating?I know Patricks sells a special made pump with the bigger pulley but it is to low on the radiator ,and I like the idea of getting a replacement locally
green48 #518909 03/19/2009 9:51 PM
If you'd like to read information on the adaptor plate install you can find it at the bottom of this page:
http://good-times.webshots.com/album/550294207eijCcS?start=132
If you click on "full sized" up in the right-hand corner of the webshots page, there is an explaination of the correct balancer/waterpump combination that will be enlarged so you can read it. I've been running this setup for 2 years with NO overheating issues.....runs thermostat (180) temperature even with the A/C.
If you note on the adaptor plate, the water ports are reduced in size while the so-called "short pump" mounts into the block itself.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
