0 members (),
80
Mod | | | Forums66 Topics128,062 Posts1,055,857 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51841 11/03/2005 12:57 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Ok guys I took out the 4 speed box in the 41 and replaced the bearings. The throwout bearing looked ok and I lightly greased it when I put it back. The tranny works well and the bad driveline vibration is gone. When I depress the clutch there is a tinkling noise. I'm wondering if the throwout bearing doesn't have enough lube as this didn't happen before the tranny was pulled. I was going to replace the throwout bearing anyway but as it takes a couple of weeks to get parts from the States and I needed the truck back on the road, I didn't. I suppose the questions are, Is it ok to use the truck until the new bearing arrives? Also if I use long guide bolts will I have enough room to replace the bearing without completely pulling off the gearbox? It was interesting refitting this old box on my own.
Thanks guys
Bob | | |
#51842 11/03/2005 11:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It won,t hurt to drive it like that. When it gets real bad you get a loud grinding noise when you push down on the clutch. You will have to pull it all the way back to replace the bearing. Did you inspect the pilot bushing when you had it out. A light churping noise when you press the pedal just enough to take up the freeplay happens sometime & is normal. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#51843 11/04/2005 2:49 AM | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Thanks for the help George. The mainshaft pilot bearing checked out ok. It was the mainshaft bearing and the clutch gear bearing that were pretty buggered. I'm still getting a lot of driveline noise when in top though and am waiting for a guy who has done a lot of work on these drivelines to come and take it for a drive. I can just about get the throwout rattle to disappear if I adjust the pedal to the point where it has way too much free play.
Cheers
Bob | | |
