| | | Forums66 Topics128,076 Posts1,056,008 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51808 11/01/2005 12:27 AM | Joined: Oct 2005 Posts: 13 Junior Member | | Junior Member Joined: Oct 2005 Posts: 13 | I have a 1950 3100 with 235 engine, that I am trying to remove, but it will not come out! The whole front end of the truck is removed, nothing in the way at all. We hook onto the engine, lift, but the studs on the motor mount need to be lifted clear to pull the engine forward. Trouble is, when we do that, the engine is up aginst the firewall, and will not clear. Anyone know a simple way? Thanks for any help. | | |
#51809 11/01/2005 12:36 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | The Studs you describe should be bolts that you can drive up from the bottom & out of the mounts. Then it should be free. Good luck | | |
#51810 11/01/2005 2:19 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | There are only three mounts. Two on the bell housing and the front under the balancer. The front mount bolts are carriage bolts and can be a pain to get the nuts off. Usually need to hold the head down while the nuts are being turned.
Fred 52 3600 69 C-10
#51811 11/01/2005 2:31 AM | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Did you undo FOUR bolts on the front mount?
Where do you have your lift attached?
You want the front of the motor tip up, tail down, as you lift to clear the firewall.
Cheers, mark. '51 KY 3100 | | |
#51812 11/01/2005 3:53 AM | Joined: Oct 2005 Posts: 13 Junior Member | | Junior Member Joined: Oct 2005 Posts: 13 | Thanks for the tips guys, I have pulled a lot of engines, but this one is tougher than it looks. I think we need to tilt a little more on the front and push out the bolts to clear the front crossmember. Thanks again! | | |
