5 members (Nick in Manitou, Peggy M, UtahYork, Southerntruck, 1 invisible), 140 guests, and 6 robots.
Topics128,077
Posts1,056,014
Members48,433
#51808 11/01/2005 12:27 AM
Junior Member
Junior Member
1 Offline
I have a 1950 3100 with 235 engine, that I am trying to remove, but it will not come out! The whole front end of the truck is removed, nothing in the way at all. We hook onto the engine, lift, but the studs on the motor mount need to be lifted clear to pull the engine forward. Trouble is, when we do that, the engine is up aginst the firewall, and will not clear. Anyone know a simple way? Thanks for any help.
The Studs you describe should be bolts that you can drive up from the bottom & out of the mounts. Then it should be free. Good luck
There are only three mounts. Two on the bell housing and the front under the balancer. The front mount bolts are carriage bolts and can be a pain to get the nuts off. Usually need to hold the head down while the nuts are being turned.
Fred
52 3600
69 C-10
Did you undo FOUR bolts on the front mount?
Where do you have your lift attached?
You want the front of the motor tip up, tail down, as you lift to clear the firewall.
Cheers,
mark.
'51 KY 3100
Junior Member
Junior Member
1 Offline
Thanks for the tips guys, I have pulled a lot of engines, but this one is tougher than it looks. I think we need to tilt a little more on the front and push out the bolts to clear the front crossmember. Thanks again!
