| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | Ok, so I was reading over Grigg's tech tip on P30 axle swaps for the millionth time today and I got thinking (which can be dangerous some times!  ) The conventional wisdom is when narrowing the P30 axle to fit under our big bolts, to make it just narrow enough to put the tires under the fenders for both aesthetics and turning radius' sake. BUT, here's another concern that's been hitherto ignored or overlooked: In all modern duallie trucks, the front tires are set to track even with the inside dual when driving straight. This makes for better handling in rain, or even more so, in that strange white stuff called snow that we have in the north. Shortening the axle "just enough" to fit inside the front fenders may lead to tighter turning radius, but at the expense of handling in poor weather conditions..... Am I overthinking this or is this a real concern that needs to be addressed?
-Matt
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | In all modern duallie trucks, the front tires are set to track even with the inside dual when driving straight. Are you sure this is actually the case? I've not done any recent research but it appears to me that the track width of the front of some dual wheel trucks would not fit that pattern.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Thanks, I did think about that, but I was not concerned... should I be? I'll have to go measure mine with both the front and rear axle swap, I know the track widths don't match perfectly, but I forget how far off.
Any other thoughts on the matter?
Grigg | | | | | Joined: Aug 2008 Posts: 138 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 138 | The reason I'm thinking about handling, is, at least with snow, the front wheels are going to cut a track, then the back wheels come along and cut two different tracks, filling in the first track..... It just struck me as non-desirable.....
Maybe it doesn't matter......
-Matt
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I think you may be overthinking this. I'd suggest wandering around a couple of car lots that sell dually trucks with a tape measure. Look for dually pickups and box trucks and even school busses.
One reason I say this is look at the tracks trucks make while making any kind of turn. You often have as many tracks as tires but yet it does not create an unsafe condition.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My narrowed P-30 front axle measures 59.5" center to center of tread (on 22.5" wheels/tires).
The rear P-30 axle measures 57" center to center of the inside dual wheels.
That's only a difference of 1.25" per side away from perfectly tracking in each others foot prints.
However, I narrowed that axle more than I should have (first installed in it the 1 ton) If I remember right it was about 1.625" to narrow per side than stock. When I do it again I'll probably make it a little wider than stock, so the difference in front track to rear track width per side might be 3.25", or 6.5" total. That would make the center of the front tires track close to the outside edge of the tread on the inner rear duals. Or in other words only half way overlapping tread, and half way not.
Confusing enough?
I'm still not worried about it.
Grigg | | | | | Joined: Sep 2008 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 77 | Chevrolet had two different widths of rearends for thier ton trucks. A narrow one for the standard cab and chassis setup and a wide one for the dually (wide fendered pickup bed) setup, at least for the 73 and up years. The front track widths did not change. I think that it really doesn't matter that much if Cheverolet did it from the factory. Just my thoughts.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The GM 14-bolt came in two widths, if I remember right: 63 and 68 inches WMS to WMS.
GM also used Dana 70 HD and possibly Dana 80 rears under some trucks, and I just don't know what the variety of widths might be with those.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The 73' + years duallys had what is referred to as an RV axle. This was a surprise to all the bodybuilders back then because it required a utility body with of 93.5" v 88.5 for a standard one ton C &C. So it really does matter which one you measure to get your info from. I'm with Old Sub on this one..too much ado about nothing. | | |
