4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#51752 10/30/2005 10:34 PM
I've attempted to determine what engine it is I have in a 49', 3800 series. With the crud removed behind the distributor, I see the following FII2IJ, can anyone decipher or lead me as to how, or am I looking at the wrong markings to find out what engine it is?????
49' Chev, 3808 platform
#51753 10/30/2005 11:18 PM
er... that doesn't look like a 216 serial. Have a look at this page and verify that the number is complete and/or correct.
(if it makes you feel any better, I didn't know what year my engine was from until yesterday when I scraped the crap off of it and ran the number.)
#51754 10/30/2005 11:28 PM
Thad, search the side of the motor for CASTING number, should be low on the block and foreward. Also look back behind the starter for date code also a casting number. Your original motor should have tall side cover, two studs holding on the rocker cover, water pump way up on the block and just under thermostat housing. My 'OLD'1940s 235 high torque motor also had the numbers 235 stamped into the pan on distributor side. good luck
1946 1/2-Ton Chevy
#51755 10/31/2005 8:13 AM
X
X Offline
That serial number reveals that the engine was built at the Flint plant (F) on November 21 (1121). The J suffix is for a '57-'62 Thriftmaster 235 backed by a 3-speed tranny. The J engine was used in the '57 34,35,3700 series, the '58-'59 31,32,36,3800 series, and the '60-'62 C10-20-30 series trucks. The casting date code on the block would pinpoint the year.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
#51756 10/31/2005 1:48 PM
Great info!!!!! Thank you Xram53.... Now I think I understand why the radiator in it now does not fit properly and has been altered. Now to try to find out what to do about the water pump/fan and find an original radiator that can be bolted in it again, any comments anyone?
#51757 10/31/2005 3:59 PM
[facepalm]
Sorry Thad. I didn't even think about looking at the 235's.
Radiators can be found from time to time in the swap meet section of the site, and they turn up on e-bay.
I know that American Classic carries them, as do several other vendors.
#51758 11/06/2005 2:26 AM
I'd like to ask for help again in establishing the the or application of the engine in my 3800 series. I now know that it is a 235, but is it possible to take it to the next step?? I, today, scrapped of the crud next to the serial# pad and located a casting number of "K197". Is this a number with the unfo I'm asking for?
#51759 11/06/2005 7:44 AM
X
X Offline
That would be the block casting date code, which decodes to November 19, 1957. That fits with the build date of 11/21 (from the serial number). This engine was likely used in a '58 model, as the '58 models were introduced in October of '57, I believe.
Curt
#51760 11/06/2005 2:02 PM
Thanks Curt, you are helpful, Thadley
