1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Chris,
My guess is that it WAS a 261 engine. Do a search in this forum using the phrase "bypass thermostat" and you will be properly educated.
Stuart | | | | | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Board=1&Number=407854&Searchpage=1&Main=56164&Words=%26quot%3Bbypass+thermostat%26quot%3B&topic=0&Search=true#Post407854
I guess the water heat for my intake should come off the top fitting and the water temp sensor for my tbi conversion on the bottom fitting as that needs to monitor the temp. Sound right. | | |
