3 members (Jon G, 2-Ton, festerhairball), 175 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#516452 03/13/2009 2:47 AM
Just wondering where on the enigne the oil pressure gauge line hooks up to.
Thanks!
1941 216?
1941 235
Do you have a by-pass oil filter set-up on the engine? If you do, a brass T-fitting might have been used where the rear hose enters the block. The oil-sender line would go into that T-fitting.
41 Chevy,
Sorry I didn't do this sooner. In THIS PHOTO, which is a '41 216, the main oil gallery is the "ridge" that runs from front to back, about halfway between the manifolds and the oil pan. Behind (to the right) of the exhaust tube, and just to the right of the curved copper oil line, is the oil pressure line hookup into the main oil gallery. You can just make out the line running up to the cowl for the gauge.
As long as your engine is a '41 235 (not the later-model 235 with high-pressure oiling), yours will be the same.
Does this make sense and sound right to you? smile
Hope it helps,
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
This helps so much! Thanks guys!
