| | | Forums66 Topics128,266 Posts1,058,369 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | I was thinking that because I need a replacement master cylinder I would update my 1 1/2 ton truck to a safer newer style double master cylinder. Does anyone know what year would be an easy install for my 1946 1 1/2 ton? I would like to keep the master cyl under the floor and I can make a new bracket but I would like to use some of the same linkage. I looked at the hydrovac unit in the tech tips but it looks like it would be a hard to find unit. Any ideas? | | | | | Joined: Jan 2008 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 165 | Nothing that would be an easy swap over, and if the wheel cylinders are new or rebuilt you really don't need one, modifing brakes and such sorta spook me on stuff like this, 1 its not enginered for the swap and 2 if an accident was to occur and fatilitys were to happen there is a possibility the local highway patrolman may do a through inspection, if some part of the modification had failed you could be liable. | | | | | Joined: Feb 2006 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2006 Posts: 42 | I certainly want to make it safer. I'll make sure I do some thourough research. | | | | | Joined: Sep 2007 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 154 | I have a 1946 big bolt. I replaced all the wheel cylinders and brake linning. I checked for a new master cylinder and realized for under fifteen dollars a I was able to rebuild the oringal one under the floor board. I can send some one through the windshied with the rebuilt master cylinder. I always believed that if its not broke don't fix it. Try and rebuild the one you have first and try it. Oh by the way, I was able to get the rebuild kit at the local Car Quest supply parts store. | | |
