9 members (Bill Hanlon, UtahYork, BarryP, NorCal52Suburban, Hanks custodian, rfs56trk, Donf, Frank50, Gazz), 141 guests, and 3 robots.
Topics128,136
Posts1,056,745
Members48,454
I have an aftermarket aluminum midrise intake from an '80s 350. Would it possibly work on a 283 or will the ports be to differnt. Both engines are stock at the moment. Would the change even be worth it? Or, do I even have a clue as to what I'm talking about?
1965 Chevy C10 Fleetside
If you think you did it right the very first time, chances are you got it wrong.
www.mfgraphpro.webs.com
If its a Edlebrock you can go to their web site and it states that the preformer will fit from 262 - 400 cu. in. engines. I am sure some of the others have the same type info.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
Riding in the Passing Lane
If its an 86 on back it will work fine. After 86 the 4 center bolt holes are straight up & down. Some manifolds are slotted to work with both. An performance aluminum intake is a good modification. Besides better runners they knock 25 lbs off the front & transfer heat better.
1972 Chevy c10 Cheyenne Super
Early 283's used the tube in the intake for an oil filler so the valve covers would have no intake hole & cap. If that's what you have then you must replace the valve covers to a later style with the hole or else no way to put oil into the engine. I think that was changed around 63-64 or thereabouts. The aftermarket aluminum's have no filler tube provision.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Compare the size of the ports. If the 350 manifold has ports noticeably bigger then the 283 heads, a step will be created that makes for extreme turbulence in the head passages. You would need to port-match the heads to the manifold runners. Not a terribly difficult task, but there's a risk of hitting water or grinding through the head if you haven't done a port-match before.
Thanks for the info. Looks like everything matches up okay. Soon as I can find a 4 barrel carb to rebuild, I'm going to put it on and see what it'll do. Then I get to pull and rebuild my 3spd. 2nd starting to slip.
