| | | Forums66 Topics128,147 Posts1,056,805 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | I have an aftermarket aluminum midrise intake from an '80s 350. Would it possibly work on a 283 or will the ports be to differnt. Both engines are stock at the moment. Would the change even be worth it? Or, do I even have a clue as to what I'm talking about? | | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | If its a Edlebrock you can go to their web site and it states that the preformer will fit from 262 - 400 cu. in. engines. I am sure some of the others have the same type info. 62Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If its an 86 on back it will work fine. After 86 the 4 center bolt holes are straight up & down. Some manifolds are slotted to work with both. An performance aluminum intake is a good modification. Besides better runners they knock 25 lbs off the front & transfer heat better. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Early 283's used the tube in the intake for an oil filler so the valve covers would have no intake hole & cap. If that's what you have then you must replace the valve covers to a later style with the hole or else no way to put oil into the engine. I think that was changed around 63-64 or thereabouts. The aftermarket aluminum's have no filler tube provision. | | | | | Joined: Feb 2004 Posts: 29,846 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,846 | Compare the size of the ports. If the 350 manifold has ports noticeably bigger then the 283 heads, a step will be created that makes for extreme turbulence in the head passages. You would need to port-match the heads to the manifold runners. Not a terribly difficult task, but there's a risk of hitting water or grinding through the head if you haven't done a port-match before. Jerry
| | | | | Joined: Dec 2008 Posts: 9 New Guy | | New Guy Joined: Dec 2008 Posts: 9 | Thanks for the info. Looks like everything matches up okay. Soon as I can find a 4 barrel carb to rebuild, I'm going to put it on and see what it'll do. Then I get to pull and rebuild my 3spd. 2nd starting to slip. | | |
