1 members (1 invisible),
46
Mod | | | Forums66 Topics128,043 Posts1,055,610 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51689 10/30/2005 5:11 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I have found some 302 gmc motor out of some WW ll duck type trucks. there are several of these. Will the military motors work with regular chevy an gmc parts. Most of these motors run good what would they be worth.
Thanks Tony | | |
#51690 10/30/2005 6:19 PM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Tony, In general, most of the parts are different. GMC parts seem to be a little higher-priced and a little harder to find than the same parts for a Chevy truck engine. The GMC 302 is an excellent engine that is more easily adapted into GMC trucks than into Chevrolet trucks (the GMC engines are a little longer than 216/235/261 Chevrolet engines. Maybe others will state an opinion on the value of an unknown-condition 302 (or, any used 40-50 year old engine). Shipping cost is also a consideration when setting a value of an engine (from a buyer's perspective). Here is a Convert to a 302 Tech Tip found elsewhere in this forum. Tim | | |
#51691 10/30/2005 10:13 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | GMC motors are similar to the Chevy motors, but very few parts interchange. The distributor is an example of what will swap. Intake and exhaust manifolds do not swap.
As Tim says hop up parts for GMC motors are not as common and generally cost more.
I have a GMC 270, which is externally the same as a civilian 302 and like the power the motor makes. I'd love to replace it with a 302.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#51692 10/31/2005 2:24 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I should have a reply for the amount of engines . There should be around fifteen or twenty of them. | | |
#51693 10/31/2005 3:21 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I would not give more than $200 for a unknown engine unless I knew for shure there was no cracked head or block, But if there was any info about past history of moter I would be pretty intresed keep us updated on what you find out I could take 2 at least:-) | | |
#51694 10/31/2005 1:10 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Military 302's have no provision for a mechanical fuel pump,use an electric pump instead.That,a few un needed lumps on the engine casting,a different front pulley is the primary differences. A stock 302 rebuild costs about same for a Chevy 261 for example,it all depends on how much work you do yourself and if you're lucky at scrounging parts. | | |
#51695 10/31/2005 9:44 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | 15-20 302s??? Are these in Missouri? | | |
#51696 11/01/2005 2:27 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | They're worthless. I'll come get them if you'll buy my gas so you can get rid of them.  Sounds like enough that I will have to make two trips. Let us know when you get them. Some of us would give our first born for one.
Fred 52 3600 69 C-10
#51697 11/02/2005 12:13 AM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | I'd give $500 each for two good engines.
x x
#51698 11/02/2005 1:36 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Stock, the DUKW would have had a 270. The DUKW is worth a lot of money, please don't part it out if it is salvageable.
Jason
#51699 11/02/2005 4:03 AM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | Yes they are in Missouri. My man should be running down the info on them as we speak. When I learn something I'll let everyone know. Also where is the casting number on the block or head so you can tell for sure what they are. | | |
#51700 11/05/2005 6:27 PM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Hey everybody, I am the guy who is going to get these engines, and as you will see from my online name here I am not a Chevrolet "expert". The info I got from some "so called expert" is that these engines couldn't be used in a civilian application due to motor mount problems. I haven't seen them yet but can't believe that it could be something that couldn't be over come. That is what Tony was really wanting to know, if they are military only. Also is there an easy way to tell a 270cid from a 302? Thanks, Jim | | |
#51701 11/05/2005 8:52 PM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | GMC motors have the size stamped on the side of the motor by the distributor. "228", "248", "270", "302"
I believe the block is cast slightly different so you'd have to modify (Grind some off) to get a normal style starter on it.
MONGO | | |
#51702 11/06/2005 5:14 PM | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | As Mongo as indicated, there are some things one has to do to make a military engine fit in a civie car or truck. They are not insurmountable by any means. The military mounting is removed/tossed and you use the area for the standard civilian application already there. Also as indicated, look behind the distributor area for a number. If there is a 302, 270, 248, 228 anywhere there, then it will fit in a GMC truck with few problems. These numbers also denote the cubic inches of the engine. GMC made other engines but I have not seen or worked with them to add or detract from the availablility of them being able to work in the trucks. Maybe someone else can throw in here. Any news yet on the sizes you have come across? How about the prices?
52 GMC Suburban...52 Chevy 3/4 ton...49 CHevy 1/2 ton Rod...49 GMC 1/2 ton retro rod project
#51703 11/07/2005 2:28 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Thanks for all the information, I have not viewed these engines yet. I was wanting to go armed with the good information I have picked up here. This is one of those deals where we are going through several people to get them. From what I know we should be able to do the deal, it just depends on how much they are and what kind of condition they are in. I only want one of them and I think Tony is in for a couple and the rest will be up for grabs. We will keep you posted. Thanks to all. Jim | | |
#51704 11/07/2005 6:17 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | I'd be interested in one, depending on price. For more 302 info, hit up inliners.org and oldgmctrucks.com. Lots of 302 guys around both sites. | | |
#51705 11/07/2005 1:26 PM | Joined: Jul 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 27 | HEY FORDGUY, YOU SAID YOU WANTED ONE MOTOR YOURSELF. DO YOU REALIZE THESE ARE DIFFERENT THAN A FORD 302??? HA,HA,HA!!!! GUESS WHO?
Insert clever statement here:
#51706 11/07/2005 11:06 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | I think I hear banjos playing in the background or is that Pat humming. See ya at the lodge | | |
#51707 11/07/2005 11:53 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | | | |
#51708 11/11/2005 11:40 PM | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | So, any updates on these engines yet? Runnin out of good weather for a road trip! I may be up for one if the price is enticing to me. How bout you Mongo??
#51709 11/14/2005 1:56 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | I talked to the middleman today, he said he is going to take himself out of the picture and get me to the owner, after that I will let everyone know how many, how much, and what conditions they are in. I still don't have a timeline yet and with the holidays coming up it's any ones guess when I will get to see them. Did get this information from the middleman however, he said the DUKWs had been re-powered with these 302s (out of the military duce and a halfs that had the automatic transmissions in them) then later re-powered again with 366s and 427s. I will keep everyone posted. Later, Jim | | |
#51710 11/17/2005 1:13 PM | Joined: Jul 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 27 | Do you think these engines really exist or are they just a "RURAL LEGEND"???
#51711 11/17/2005 7:25 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Are these from the DUKWs that run around the lakes near Branson? | | |
#51712 11/22/2005 3:48 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | They may very well be a "rural ledgend" along with the barn full of old fiberglass cobra replica bodies we were supposed to find out about and the sohc 427 craate motor that never existed. However, we gotta check 'em all out 'cause first time you don't will be the time you miss out. Talked to "the guy" this weekend and he told me where they are located so after Thanksgiving I will be checking them out. Jim | | |
#51713 11/24/2005 4:56 PM | Joined: Apr 2004 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 72 | Need any help? A road trip might be fun, just to see a bunch of old engines! :p
#51714 11/24/2005 6:00 PM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I hope they are real! Please let us know.
#51715 11/27/2005 12:43 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | I'm in for one if complete and in running order.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#51716 11/27/2005 1:41 PM | Joined: Aug 2005 Posts: 94 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 94 | If the price is right and they are useable, I might be willing to travel from NC. Anyone in NC, VA want to travel together? | | |
#51717 11/27/2005 6:36 PM | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Very tempting. If I had a 302 in my truck instead of a 235, I would probably be interested in keeping it and rebuilding it for more modern cam and better power. I think I saw something about big block Chevy rods being able to work with some crankshaft mods and a wierd overbore for the pistons. That would be an interesting project.
Anyway, anything more on the price?
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
#51718 11/28/2005 3:35 AM | Joined: Jun 2005 Posts: 49 Junior Member | | Junior Member Joined: Jun 2005 Posts: 49 | well now Im interested too. I wont pay 500 for one... but if the price is right, Im interested
the 302s have the same front mount as the 216s right??
BTW I have friends in the trucking business, so I could get a few up here to pittsburgh, pa. If that would help anyone out. | | |
#51719 11/28/2005 6:05 AM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Mac, The 302 is longer than the Chevy 216, won't just bolt in. On the AD trucks the front frame crossmember is different on the GMC's. Mongo | | |
#51720 11/28/2005 11:08 PM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Guys, Too early to talk about prices 'cause first we gotta see 'em and then we gotta negotiate to get 'em. What I intend to do is look them over and take inventory then shoot him a price, trying to average out the good ones with the ones that would be for what parts could be salvaged. Should be able to see them this week. My goal is to get one for myself and I am sure Tony wants one and we will try to get the rest to anyone else who wants one. More later. Jim | | |
#51721 11/29/2005 1:27 AM | Joined: Jun 2005 Posts: 49 Junior Member | | Junior Member Joined: Jun 2005 Posts: 49 | | | |
#51722 12/12/2005 1:50 PM | Joined: Jul 2005 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 27 | Hey Ford Guy, thought I was going to get up to see you but have not had the time. Took the old Doodlebug out and limbered it up the other day. The motor smokes pretty bad and you know what the Surgeon General says about smoking!!! You mentioned after the holiday on the 302's. Do you mean after the holiday season? Because I know it is a hectic time for most people, myself included. Hope to find time to visit soon.
#51723 12/13/2005 12:00 AM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Still interested.  | | |
#51724 12/13/2005 1:46 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Well, yeah I meant after Thanksgiving, but I am going to extend it 'till after the holidays 'cause you know how busy it is around here. I bet if you put some Sea Foam in that old Doodlebug you could fix anything that is wrong with it, and the smoking too. You know Tony uses it, I think he chases it with Keystones though. Later! | | |
#51725 12/21/2005 1:47 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Don't give up on the 302s! My guy tells me this is a real deal. We are getting close, I will take my camera with me. Can you post photos here or do they need to go somewhere else? | | |
#51726 12/21/2005 4:08 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | They have to be posted on another server and linked to. | | |
#51727 12/22/2005 4:54 AM | Joined: Jul 2005 Posts: 16 Member | | Member Joined: Jul 2005 Posts: 16 | Okay, don't know if I know how to do that, but I will wait 'till I have the pictures before I seek further information on how to do it. Looks like I will be going tomorrow. | | |
#51728 01/15/2006 9:18 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | | | |
