3 members (JW51, tesa, Ponchogl),
49
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51643 10/29/2005 1:44 PM | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | Having a problem removing the front seal on the TH 400, what gives? | | |
#51644 10/29/2005 2:54 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | gotta give it hell., it will come out,
they are in there pretty good most of the time
dont be scared
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
#51645 10/29/2005 10:43 PM | Joined: Apr 2000 Posts: 247 Member | | Member Joined: Apr 2000 Posts: 247 | If you have it out, I'd go ahead and replace the o-ring seal too. If you don't know what I mean, have a shop do it. It won't cost that much and will save you a lot of grief if it is leaking too. | | |
#51646 10/29/2005 11:16 PM | Joined: Feb 2004 Posts: 29,778 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,778 | Drill a hole in the seal and screw in a big sheet metal screw. It will either push the seal out of the housing, or give you a place to grab with vise grips to pull it out. I always remove the pump, and change the torque converter support bushing, the O ring, and the pump gasket. That covers all the possible leak points, and if you don't change the bushing, the seal will fail again in just a few miles. Jerry
