9 members (walterhvogel, Jay R, DadsFirstPickup, moparguy, JW51, Jon G, Gray_Ghost, Stovebolt48, 1 invisible), 59 guests, and 0 robots.
Topics128,079
Posts1,055,941
Members48,430
#51643 10/29/2005 1:44 PM
Junior Member
Junior Member
Having a problem removing the front seal on the TH 400, what gives?
#51644 10/29/2005 2:54 PM
gotta give it hell., it will come out,
they are in there pretty good most of the time
dont be scared
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
#51645 10/29/2005 10:43 PM
V
V Offline
If you have it out, I'd go ahead and replace the o-ring seal too. If you don't know what I mean, have a shop do it. It won't cost that much and will save you a lot of grief if it is leaking too.
#51646 10/29/2005 11:16 PM
Drill a hole in the seal and screw in a big sheet metal screw. It will either push the seal out of the housing, or give you a place to grab with vise grips to pull it out. I always remove the pump, and change the torque converter support bushing, the O ring, and the pump gasket. That covers all the possible leak points, and if you don't change the bushing, the seal will fail again in just a few miles.
