1 members (Hotrod Lincoln),
327
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | Are the ball studs,tie rod ends,and drag link all the same on a 1946 Chevrolet 1/2 and 3/4 ton truck. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Oldtruck1946, according to my Canadian parts book the drag link is the same, the tie rod ends are different, and the third steering arm is different [the one the drag link attaches to], hope that helps. | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | 3B's right, the ball studs use a tapered shaft. To get them off you have to drill out the center and drive them out. Plus side is they still make them ($$) and they are available with threads that use a castle nut and cotter pin.
You ought to get end kits for the old style tie rods as well. From what I could find, modern tie rod ends with the correct tapered shaft are not available for the 3/4ton.
If you get into the kingpins, that's another story. They really need to be taken to a shop,pressed out, and line bored. | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | I just went out a looked at my 46 1/2 and 3/4 ton trucks. The 1/2 ton tie rod end caps will inerchange with 3/4 ton tie rod ends and the drag link. So I think this means that I can get parts for it. | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Do not know about the items you mentioned, butI do know the King Pins are different on the 1/2 & 3/4 ton truck. King Pin Set GM369111 is for the 1946 1/2 ton truck. Harold
Harold Is a restoration ever finished? | | | | | Joined: Feb 2008 Posts: 158 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 158 | Yeah the king pins in the 3/4 ton are bigger than the 1/2 ton | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | The ends should interchange. If you want new balls I think the shafts are different, but are available. I believe the arms are different castings between the two models. Kyle | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have to add a comment here. I rebuilt the front end on my 1951 1 Ton and the steering is centered perfectly. If nothing is bent there is no need for an adjustable drag link. Also the old style ball and socket joints are good and snug and not dangerous at all.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I support that completely Fred. All of my front end components are new and the truck steers and behaves just fine at highspeed and steers just fine at low speed also. No problems. Denny Graham Sandwich, IL
Denny G Sandwich, IL
