1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
Need to pull the speedometer on my 65 so I can send it off for repair. So I took out the screws for the dash, but it doesn't seem to want to come out. Is there a trick to this? Am I just being too careful? Or is there something else I need to remove? ohwell Any help is much appreciated, as I cant afford tickets I am guaranteed to receive if I dont know how fast I'm going. The new engine is much more than I really needed! dang
Give me my Truck, or...my truck daamit! Cause i aint leavin without it!
http://picasaweb.google.com/jadefalcon1218/MyK10
Have you disconnected the speedo cable and wiring at the back?
I am also trying to remove my instrument panel on my 65 c20, i have gotten it loose by removing the choke and ignition switch but i cant seem to find the way to remove the headlight and wiper knobs. any help would be very appreciated.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
I was actually hoping that it would allow me to get it out far enough to do the disconnecting without out taking some meat off my hands trying to do it from under the dash. Apparently will have offer a little flesh to the "Big Bolt in the sky" on this one. cry
I finally got it removed. There were small set nuts on the control knobs for the wipers,choke, and headlights. I removed that nut, slipped the knob off then unscrewed the chrome plate holding the back of the knobs on and it came right off. The spedo cable was very easy to remove, it just had the one nut holding it on and i was able to hand loosen it. The only knob that did not work this way was the head light, i had to take the drimmel and cut it at the base of the knob to remove it. A new one is only 10 dollars at lmc.
To remove the headlight knob, you should have reached up under the dash and felt on the switch. On the topside of the switch is a button. Push that little button down and you can pull the headlight knob, complete with the rod, out of the switch.
Don's 65 K10: Usually you can pull them forward a little to get a bit more space, but sometimes you can't. In this case you really may just have to bear down and offer up your pound of flesh.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Will have to wait till I get back, I'm headed to Boise, ID for the weekend to visit the Wife's family.
I spent a week in Boise one night.
dj durant
More pix on Flickr
That must have been one WILD night. I've had a couple too many and lost a day or two, but a whole WEEK? We need to see pix of a party that major! eek
