0 members (),
118
Mod | | | Forums66 Topics128,186 Posts1,057,320 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51554 10/27/2005 3:41 AM | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | I'm kinda swinging in the dark. I was wondering if anyone knows about the axles and hubs on a 1 ton rear end from 1957 on up ? Are they all the same ? What years interchange etc. ? Thanks for your patience, Willis | | |
#51555 10/27/2005 5:46 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | If you stick with the 10 bolt, axles will interchange from 48 to 72. But you have to use the correct length, which varied. I know that you can cheat on the length a little, I learned that from an older junkyard man.
Hubs are another story and are dependant on bearing size. I think an interchange manual would be a good place to start.
Fred 52 3600 69 C-10
#51556 10/27/2005 2:30 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Like Fred said, the Eaton H0xx series axle started with the 47.2 trucks and kept going through 72. There were several gear ratios and widths available, parts should be relatively easy to find at your local Napa or Car Quest. The internals of the carrier changed slightly around 63 or 64. Search for Eaton axle on here, everything you can want to know has been covered (except whether the later finned brake drums are the same size as the earlier smooth drums...I'd like to know that myself). | | |
#51557 10/27/2005 2:49 PM | Joined: Oct 2005 Posts: 2 Junior Member | | Junior Member Joined: Oct 2005 Posts: 2 | Thanks guys ! I'm new to this site and I am impresssed with the quick replies. | | |
#51558 10/31/2005 3:48 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I do know that the no spin rear end availible in the later ones is very tough. Also that a certain size (I think it was 11.5 inch) brake drums used on certain 4x4 models are almost inpossible to find | | |
#51559 10/31/2005 9:49 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | The Detroit Locker unit (sold by GM as an option, I think they called it NoSpin) was available as an aftermarket part, too. I have one in a 4.57 differential, it's going to be installed in my 4.10 open pumpkin. It's the only one I've ever seen on eBay in four years of looking - but I got it for the opening bid. From what I understand, the DLs will work in any of the 47-72 Eaton H0xx differentials. | | |
#51560 10/31/2005 10:31 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I used to use the latter model drums on those by haveing the holes drilled out & use the latter larger studs. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#51561 11/04/2005 9:23 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wrenchbender, could you please give us some details? What years with what drums? This sounds like one of those hints that money can't buy! | | |
#51562 11/04/2005 9:47 PM | Joined: Nov 2002 Posts: 59 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Nov 2002 Posts: 59 | Actually the 1946 DR 3/4 ton and DS 1 tons used the full floating eaton axle complete with 8 lug wheels and were the first trucks to use the forthcoming advance design hubcaps | | |
#51563 11/04/2005 11:15 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I used to get the equivelant size drum from 77 up. The single rear wheels were 13X2 1/2. Than get the new studs to match & drill the holes in the hub to allow them to be pressed in. I used to have the machine shop I traded with do it but a guy could do it himself with the right size drill bit & a drill press. You will need new lug nuts because they are a larger size. The wheels fit fine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#51564 11/04/2005 11:36 PM | Joined: Feb 2005 Posts: 37 Junior Member | | Junior Member Joined: Feb 2005 Posts: 37 | I am going to swap an Eaton under my truck.
Currently I am taking it apart to convert to disc brakes, using brackets for a 14 bolt.
Also, if you can't find a No-Spin (Detroit) for these the 14 bolt detroit locker WILL fit inside the carrier, but you will have to use 14 bolt axle shafts to match (30 vs 17 splines). The ring gear is like 10.25", a little smaller than the 14 bolt.
1969 GMC K/2500 (w.i.p.)
