0 members (), 348 guests, and 6 robots.
Topics128,162
Posts1,057,042
Members48,463
Thinking of giving it a shot, the air noise of the direct drive fan is loud in the Grumman.
Will this be a standard Chevy 292 item, or will I have to use one intended for another engine? Any tips are greatly appreciated!
Riding in the Passing Lane
It will will work fine if you have enough clearance between the pulley & radiator. There are 2 sizes of bolt patterns on the pumps & pulleys for this. The 292 generally uses the larger one. If you match that up it should work. You might consider an electric fan. Is there a photo of your Grumman on here anywhere. I'm an old Step van mechanic. The Grumman was the best body.
1972 Chevy c10 Cheyenne Super
Cool, I will take the fan with me so I'm sure to get the right one.
Pix links in this post
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=509357#Post509357
