Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Woodcmiami, tclederman, Otto Skorzeny), 145 guests, and 3 robots.
Topics128,282
Posts1,058,496
Members48,490
#5153 09/23/2003 5:44 PM
Junior Member
Junior Member
My 215 Poncho straight six has a lifter or two that are very noisy. I checked the adjustment and it is ok. A friend of mine said I could replace all my lifters even though the cam isn't brand new. I always thought that the cam had to be replaced with the new lifters. Is that just an old wives tale?? :confused:
LET'S GO ISLANDERS!!!
1963 Chevy 1/2 ton fleetside w/'65 Pontiac 215 6cyl.(not the OHC engine!)
1950 Ford 2 door sedan-project
#5154 09/23/2003 7:07 PM
You can break in new lifters on an old cam, but not old lifters on a new cam. And check the rest of your valvetrain for wear before you go replacing lifters. Perhaps cleaning the gunk out of the lifters may help. Are they hyd lifters? What year is the engine?
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#5155 09/24/2003 11:31 PM
You might be able to stop the lifter HYD lifter noise by adding 1/2 quart of tranni fluid to the oil, this most times cleans and frees up the lifter. then change the oil after the noise is gone.
