5 members (KEVINSKI, FAST55, Hanks custodian, Otto Skorzeny, Rusted Nut), 66 guests, and 6 robots.
Topics128,075
Posts1,056,007
Members48,433
I know someone out there has replaced the rear spring eye bushing for the shackle. I have given up. Is there a secret method?
Hi Tom,
If you do a search you will find some good information on how to do this. One of the most common methods is using a nut and bolt with washers and using the srew action to pull out the bushing. You can also carefully cut a section of the old bushing out, making it easier to remove the rest of the bushing.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Check here.
Bruce
My Trucks
Stuff I Collect
Thanks!
I just did mine last week. I used my airhammer they came out.putting them in is something differant.
a ball joint press works pretty good or a vise if it's off the truck .if you got some sockets or round stock cut to length to push it out .
