5 members (5 Window 9434, JW51, Ponchogl, Mike Roache, Charles in CA), 66 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#514503 03/08/2009 12:59 AM
I'm setting up a supercharger on my 235. Does anyone know what if any other harmonic balancers and crank pully will work. I need a 10 spline belt to drive the charger.
thanks
chpewah #514508 03/08/2009 1:05 AM
not really but would love you to keep a photo record of what all you had to do, mods ect.. to make it fit as well as part numbers ect..
1937 1/2 ton
I
I Offline
You probably will have to modify one from a 250 six from what I have been told. I'm looking for a double sheaved balancer for a 235 also. I was told a 250 balancer would work.
Iron Clad
you will need to make a custom lower pulley for your 10 groove micro-vee.
Thanks, I though I might have to create a pully. I'll do some more scouting in the junk yard and see what might be a good candidate. I'll keep you posted. Just starting to gather the parts now. the eaton M-90 showed up yesterday and seems to fit nicely inder the hood.
