1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | What motor mounts are you guys using to install a 350 into your '64 C10? The block is a newer one piece rear main seal block if it makes a difference.
What radiator hoses are you using?
Thanks a ton!
'64 C-10 Longbed Fleetside Custom with large window. BRE 383 stroker with Turbo 350.
| | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | 44 views and nobody can help me? I've been searching until I go crosseyed for pictures or something. I'm finally dropping the motor in after a year of waiting and could use your help. Thanks!
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Give me chance to get you the part number this afternoon. As a matter of fact, I have one spare sitting in the shop. LMC sent me two replacements when I only needed one, and then wouldn't let me send it back to them. I should be able to get you the info by about 6pm tonight. Work on graveyard shift and must get the sleep in before the kids get home!  | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | If you like, PM me your number and I'll get a hold of you as soon as I'm up. | | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | Don; Thank you so much for the phone call and help. After looking at your pics; I discovered my motor brackets are not stock. Mine actually bolt to the top of the frame with two bols and the bottom bolts through the engine cross member with one bolt. They are a factory piece but not from this year truck???
| | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Not sure as I've only worked with my truck. You might check on the trans/driveline section and ask someone who has made the turbo 350 mod what they did? Sorry I'm not able to help more, but I've just caught this addiction and only have the one truck.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | 4 x 4 and 2 x 4eng mounts are totally different from one another. what you are describing in yours sounds correct. some of the later perches will mount in their place to takke the later insulator( the one that has the horizontal bolt running through it. perhaps this link will help you, http://www.speedwaymotors.com/LS1-Motor-Mount-Adaptors,5070.html. if not check some of the aftermarket shops as most will have something. http://advanceadapters.com/product/3961/(P/N-713088-P).html ron | | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | 4 x 4 and 2 x 4eng mounts are totally different from one another. what you are describing in yours sounds correct. some of the later perches will mount in their place to takke the later insulator( the one that has the horizontal bolt running through it. perhaps this link will help you, http://www.speedwaymotors.com/LS1-Motor-Mount-Adaptors,5070.html. if not check some of the aftermarket shops as most will have something. http://advanceadapters.com/product/3961/(P/N-713088-P).html ron BINGO! I just discovered the same. The 2WD brackets are correct on my truck. I just don't understand how I pulled a 350 out of the truck, but the new 383 won't drop right in. It is oh so close. I just can't line up the one side when I try to put the bolt through the bracket into the rubber motor mount. It's like I need a 10 ton press to push the engine farther down between the brackets. I guess I'll have to notch the holes in the brackets so they spread wider apart.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | just try slackning all the bolts off a little to give you a little wiggle room and then tighten them up when you have all the bolts in. was the truck ever smacked? but what is different between the 350 that you took out and the 383 that is going in? anything? ron | | | | | Joined: Aug 2008 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 72 | Sorry if I set ya on the wrong path Desertchevy, didnt realise there was a difference between the 2wd, and mine.
| | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | just try slackning all the bolts off a little to give you a little wiggle room and then tighten them up when you have all the bolts in. was the truck ever smacked? but what is different between the 350 that you took out and the 383 that is going in? anything? ron I've actually removed the bolts that go through the top of the frame rails and brackets. Bottom is loosened. The 350 and 383 should be the same width. All I can figure is that the old rubber motor mounts were a tad thinner. ???
| | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | What counted is that you went out of your way to help a fellow stove bolter. Thanks again!
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | just try slackning all the bolts off a little to give you a little wiggle room and then tighten them up when you have all the bolts in. was the truck ever smacked? but what is different between the 350 that you took out and the 383 that is going in? anything? ron I've actually removed the bolts that go through the top of the frame rails and brackets. Bottom is loosened. The 350 and 383 should be the same width. All I can figure is that the old rubber motor mounts were a tad thinner. ??? did you get it together? those old rubber mounts get a little oil soaked over the years and do sag a bit, just like people. new mounts would be a little higher which in theory would bring them a little closer together ron | | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | just try slackning all the bolts off a little to give you a little wiggle room and then tighten them up when you have all the bolts in. was the truck ever smacked? but what is different between the 350 that you took out and the 383 that is going in? anything? ron I've actually removed the bolts that go through the top of the frame rails and brackets. Bottom is loosened. The 350 and 383 should be the same width. All I can figure is that the old rubber motor mounts were a tad thinner. ??? did you get it together? those old rubber mounts get a little oil soaked over the years and do sag a bit, just like people. new mounts would be a little higher which in theory would bring them a little closer together ron No luck.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | how far off are you? are you lifting the motor so as to take the weight off so that you can wiggle it a little. are you sure that the frame has never been whacked (in an accident0 ron
| | | | | Joined: Oct 2007 Posts: 28 Apprentice | | Apprentice Joined: Oct 2007 Posts: 28 | how far off are you? are you lifting the motor so as to take the weight off so that you can wiggle it a little. are you sure that the frame has never been whacked (in an accident0 ron I even lubed the brackets and motor mounts with dish soap. I can line up the bolt hole on one side but not the other. Either the right side motor mount will line up to the hole in the bracket or the left side will. Can't get both to line up.Three different people have tried it now with no luck and alot of frustration.
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I sent you a pm ron
