Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Hotrod Lincoln), 60 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#51394 10/20/2005 9:59 PM
I need to change the transmission gasket on my 64 chevy truck. I am having trouble getting under it cause my truck is lowered a bit. Even though it seems kinda difficult cause i cant seem to get a hold of two bolts that are located between the pan and the frame. Any ideas on how wat i should do. Should i take it to the shop? I do not have anyone to help me.
Stovebolt-It is painted
#51395 10/20/2005 10:08 PM
Riding in the Passing Lane
This time i,m going to assume it,s an automatic. ( See carrier brg. noise.) You will have to unbolt the trans mount, raise the engine a little with a jack, unbolt the crossmember & move it back a little. You can do it if you raise the truck & secure it safely.
1972 Chevy c10 Cheyenne Super
#51396 10/21/2005 7:22 AM
oops i forgot to mention it is a automatic. Sorry. Thank you wrench. I will see wat i can do.
#51397 10/28/2005 5:08 PM
realy long ratchet drive extension is the trick
long enough ot go way back to around end of the tranny
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
