1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51394 10/20/2005 9:59 PM | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I need to change the transmission gasket on my 64 chevy truck. I am having trouble getting under it cause my truck is lowered a bit. Even though it seems kinda difficult cause i cant seem to get a hold of two bolts that are located between the pan and the frame. Any ideas on how wat i should do. Should i take it to the shop? I do not have anyone to help me.
Stovebolt-It is painted
#51395 10/20/2005 10:08 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | This time i,m going to assume it,s an automatic. ( See carrier brg. noise.) You will have to unbolt the trans mount, raise the engine a little with a jack, unbolt the crossmember & move it back a little. You can do it if you raise the truck & secure it safely. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#51396 10/21/2005 7:22 AM | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | oops i forgot to mention it is a automatic. Sorry. Thank you wrench. I will see wat i can do.
#51397 10/28/2005 5:08 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | realy long ratchet drive extension is the trick
long enough ot go way back to around end of the tranny
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
