2 members (Wooley, Hotrod Lincoln), 81 guests, and 3 robots.
Topics128,096
Posts1,056,488
Members48,444
Okay,my Grumman 292 2ton with dually rear end may have had another rear end {or tranny} installed, changing the final drive ratio. Reason I say that is a PO put stickers on the speedo, showing a higher new speed, ie 30mph indicated equals 40mph on the road. Sure would like to run into one of those roadside automated radar signs for verification.
Problem is, I dont like the rpm the engine has to turn on the road. At approximately 60mph, the engine is running just over 3000rpm. Of course 1st gear of the 4 speed tranny is absolutely useless. Sure would be nice to run 60 at about 2K or so!
Is there a component I should be watching for to solve the high rpm/useless 1st gear situation?
Those roadside signs are great, aren't they? The ones that I have seen are solar powered, quite amazing.
1951 1 Ton Completed
Sure beats finding the cycle officer with the handheld laser for speedo verification {and random taxation}!
ODSS President
ODSS President
Borrow a hand held or dash mount GPS,gives constant MPH.
~ Cosmo
1949 Chevy Half Ton
On a 2 ton rig, transmission choices are scarce. Maybe a Clark 5 speed with Overdrive, and possibly an NV4500. Of course you could get a gear venders overdrive to fit between the transmission and the rear axle.
Riding in the Passing Lane
You can match the odometer reading against the mile markers on the freeway & check the speedo. If the odometer matches the speed will be real close.
1972 Chevy c10 Cheyenne Super
No such thing as a 4.11 differential for a 2 ton, eh?
That Gear Vendors OD would more than double my total vehicle cost! Not in the cards.
The search goes on...
