2 members (Joe H, Naturalthud), 196 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#512198 03/02/2009 3:06 PM
Hi, I started taking the doors apart today and the passenger door is good but the drivers door is rusted thru 2 to 3 inches up from the bottom on the inside is there a patch for this repair this area has a offset so it would be hard for Me to repair , Thanks , Pete
Pete52 #512204 03/02/2009 3:21 PM
If this is a 52, yes they make a panel for this. They are called inner door bottoms. I can't imagine the outer skin not being affected too. They make nice lower skins for this purpose too.
1951 1 Ton Completed
truckernix #512533 03/03/2009 6:39 AM
it's not that hard Pete, I used a MIG welder, and they came out good, can't notice the patch at all. got mine from Jim Carter
bluedot38 #512590 03/03/2009 2:19 PM
Pete,
Different year trucks but I kept a photo journal that may help you decide what avenue is best for you. Pics starts here. And a few more here. Hope this helps. Have fun and good luck
Dan
Chev4t6 #512618 03/03/2009 3:47 PM
Pete...I replaced the lower inner door skins on my 53 also. With that area, you have to be very careful of warping from the heat of the mig. I used 1" angle iron on the inside of the door to brace the inside of the door before I welded on the new patch. It really helped. My webshots shows the bracing I did if it'll help ya.
~Ron
Chev4t6 #512624 03/03/2009 3:52 PM
Thanks , good pics ordered the patch and will give it a shot soon ,New to this body work , Pete
Pete52 #512845 03/04/2009 3:46 AM
I used the angle irons to provide a reference to where the door bottom should be. Once you cut away the inside door bottom, the ouside skin is like a flap of paper. I tacked the angle iron from the top of the door and mid way down. I located the ends at the exact location of the bottom. Although there are contours in the door, I believe the top, bottom of the window opening and the bottom all line up in the vertical.
truckernix #513167 03/05/2009 12:44 AM
Thanks, where the outside folds over the inside around the edges am I seeing the repair right that You grind off the folded lip ,then weld or tack the two pieces back together , Pete
Pete52 #513188 03/05/2009 1:25 AM
Well I did the outside skin too. In my case, the skin is bent over the inside structure using a hammer and dolly. I suppose that it could be welded as you say. I would imagine that the original method was probably the fastest and cheapest for the factory.
truckernix #513753 03/06/2009 3:29 AM
Tommorow is the day My frist shot at doing body work ,inside door skin on My 52 3100 Anyone out there just do a inside skin do you think I should try and and pull the folded metal over and then fold it back or remove it and spot weld the two together? Pete
Pete52 #514463 03/07/2009 10:42 PM
Well, all done it took almost 5 hours , made My own tool to open the fold from a old pair of channel locks and My bench grinder did a good job of getting it open than cut rusted section out of bottom than fitted patch to door cut that than the mig weilder spot it in , butt welded of course , and scratch My frist body work project DONE!!!!!!!!!!! Thanks for all the help, Pete
