8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible),
58
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,699 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | hi,
my wipers dont work and after lubing and cleaning the vacuum wiper unit i'm looking at having the unit rebuilt professionally or buying an electrical unit.
i have never been in a car/truck where the vacuum powered wipers worked well but thats because all the units were old and worn out. how well do they work when they are in tip top shape?
i like the idea of keeping the vacuum wipers and the price of a rebuild oruying electrical is about he same.
would anyone care to shead some light or make any sugestions?
thank you
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | All vacuum wipers stall under acceleration unless you have a fuel pump with a vacuum booster. Take that with a grain of salt, I've read that the fuel pump booster will keep the wipers working during acceleration but not had the experience myself. It's just a fact of life that they'll never be as good as electric. I kept the vacuum wipers on my 38. I just think of them as the original delay wipers.
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | I have a booster on my fuel pump. I'm leaning towards keeping it origional. how bad could they be? my truck is already slow, loud and handles poorly (compaired to a 2009) slow wipers just add to the character. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | put a vacuum resevoir (sp) in line to hold some vacuum under accel kinda like a tomato juice can... | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i had my wipers overhauled by flicken and they work ok. have the dual action pump. i use rainx and it helps so i rarely use the wipers except at very low speeds. still not as good as electric.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Mar 2009 Posts: 124 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 124 | thanks for the insight folks. i'll look into getting a resevior. | | | | | Joined: Mar 2009 Posts: 7 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 7 | electric wipers will make you very happy | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | Just "rebuilt" the American-Bosch wiper motor that was on my '41 1.5 ton. Has a "47" stamped in the case, guessing that's the year it was installed. The wire was run from the switch (above the windshield to the R. of the wiper motor) through the original vacuum line, down to the light switch for power.
Thought that was kinda cute.
Anyway, knowing they put it there 6 years after the truck was born makes me mind less that it's not "original". And, works well, no matter engine speed.
-Michael | | |
