| | | Forums66 Topics128,162 Posts1,056,936 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Fellow Stovebolters, I am working on a 1946 Chevrolet model DS 1-ton Panel truck. I want to change the gear ratio in the rear end from its present 5.14 ratio to a higher 3.90 or 4.11 ratio. The research I've done tells me they used the same rear end in 1946-1960 Chevy 1 ton trucks. Can anyone tell me if this is a Dana rear end and if yes what model? This unit has a pumpkin that can be removed as well as a rear cover plate. Thanks in advance! Brian [email protected]949 973-6224 | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | It's a Eaton rear end. A pumpkin from a 68-72 3/4 ton should swap out directly.
You could find a 4.10 or more likely a 4.76, 3.90 will be near impossible to find.
I've got a 46 DS pickup, where you at in California? You could check out my T5 behind a 235. I decided to keep the 5.14 rear end and use a .63 o/d. Works out to be a nice combo.
Greg | | | | | Joined: Nov 2004 Posts: 65 old truck heaven | | old truck heaven Joined: Nov 2004 Posts: 65 | Hi Greg, Thanks for the reply. I like that idea. I have a 235 engine also .....and I could still have the low ratio if needed. I started looking for a 1967-72 3/4 ton rear end today.....just may have found one. I live in San Juan Capistrano,CA ( southern CA). I did find that the 4.76 is easy to find....but am holding out for a 4.10 Brian | | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Hey Brian,
Also ping Dave Murry out in Florida. He has a DS Suburban that he just did a full rear end swap. It costs a bunch more but you'll get to pick the ratio that you want.
If you keep at it you'll eventually find a 4.10, best of luck.
Greg
