1 members (1 invisible), 137 guests, and 3 robots.
Topics128,186
Posts1,057,306
Members48,467
Does anybody have pictures of their running boards during assembly? I have a 48 1/2 ton.
Do the running board attach directly to the braces on the frame? Are there any other brackets?
I need to know how many braces attach to the fenders? I have a few but don't know which ones I need.....
PICTURES ANYBODY
HELP!!!!!!!
Tom
48 Chevy 3100 Shortbox 5 window
"The Big Dog"
Tom,
I didnt take any pics but on my 52 the runnin boards bolt directly to the 3 brackets attached to the frame and then 3 bolts through the lower section of the rear fender with a gasket between.
the only thing I did was start all the nuts on the frame brackets then slipped in the gasket on the rear fender and alighned the runnin board for a nice fit and snugged up those 3 fender bolts then proceeded tighten up the rest..it went pretty smooth.
As far as any additional brackets????..mine did not have any and still does not.
Hope this helps.
Tim
1952 Chevy Shortbed
Photos in Photobucket
I
I Offline
The running boards use 2 carriage bolts in each of the 3 brackets. Pretty sure they are 5/16th they slide in to the running board and are held with clips.
The fenders front and rear each have one brace at the rear to the frame. You can get them from LMC cheap but are also easy to make
Perfect thats kinda what I thought.
Anybody have anypics of the fender suppors?
Tom
"The Big Dog"
