3 members (carbking, DaveV, 1 invisible),
81
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,136 Posts1,056,427 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51208 10/17/2005 1:59 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | Help. i've got the collar off and the 4 bolts holding the bell housing to the transmission but i can't get the stupid bell to slip back to expose the u-joint. what am i doing wrong?
p.s. I have a pic but don't know how to post it. thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
#51209 10/17/2005 2:04 AM | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Old Blue,
Did you unscrew the collar(part around the torque tube) at the rear of the bell neck?
Glenn, | | |
#51210 10/17/2005 2:33 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | yes i got the collar unscrewed. the bell is in there real tight. i took the 8 bolts out holding the bigger plate to the transmission but it started to leak fluid so i put them back in. i assume the 4 bolts holding the bell collar on is all i need to remove? do i need to take the sledge hammer to the bell? help?
#51211 10/17/2005 4:16 AM | Joined: Jun 2005 Posts: 153 Member | | Member Joined: Jun 2005 Posts: 153 | i got the bell loose and the ujoint out. now, how do i tell if the u-joint is bad? it doesn't have any balls in it like i expected, and it's got about 1/16" slop back and forth between the caps in the axle side (not the brass flanged sides). it doesn't work as smooth as ball bearing models and i'm surprised this design works as well, but can someone tell me how to know if this thing is bad?
thanks.
