10 members (TexasJim50, Jay R, TUTS 59, Hotrod Lincoln, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, 1 invisible), 89 guests, and 2 robots.
Topics128,134
Posts1,056,411
Members48,441
Help. i've got the collar off and the 4 bolts holding the bell housing to the transmission but i can't get the stupid bell to slip back to expose the u-joint. what am i doing wrong?
p.s. I have a pic but don't know how to post it.
thanks
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
Old Blue,
Did you unscrew the collar(part around the torque tube) at the rear of the bell neck?
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
yes i got the collar unscrewed.
the bell is in there real tight. i took the 8 bolts out holding the bigger plate to the transmission but it started to leak fluid so i put them back in. i assume the 4 bolts holding the bell collar on is all i need to remove?
do i need to take the sledge hammer to the bell?
help?
i got the bell loose and the ujoint out. now, how do i tell if the u-joint is bad? it doesn't have any balls in it like i expected, and it's got about 1/16" slop back and forth between the caps in the axle side (not the brass flanged sides). it doesn't work as smooth as ball bearing models and i'm surprised this design works as well, but can someone tell me how to know if this thing is bad?
thanks.
